Powder Coating
El Camino Junkie
144
WALTERS, OK
Not sure where to ask this, but can headers be powder coated if htey are going to be used for street use. I dont want to spend a ton on ceramic for street use, but paint will just burn off after time. Will the powder coating do the same?
bowtie81
5,008
sarnia, ontario canada
the powder coating will stay on. it will help reduce under the hood temps on the street and make the headers last longer
bowtie81
5,008
eastwood makes a powder coating you can do at home, save alot of money
bowtie81
5,008
ive seen other guys get it done and never burnt off. it cost them a bit more than 40 a header. call around to some different places and even check the eastwood company
78mali350
216
Helena, AR
I didn't know you could powdercoat those either. Sounds like a pretty good idea and a good price for what you found
jrdrag
182
Rochester, NY
It WILL burn off. There may be some high temp stuff out there but 90% of it is just a plastic coating and will last only slightly if any longer than paint. There is a reason no one sells powder coated headers in catalogs. That is also why ceramic is so popular. It is really the only technology that works.
