Power Brake Booster holes
TURNA
6,028
Socialist NY
Are the 4 holes on the firewall that the power brake booster studs go through the same on all the brake boosters?????
Example ==> would a 1980 Camaro brake booster fit onto a 1980 Malibu firewall without modification?
TURNA
6,028
Socialist NY
NOBODY KNOWS?????
Does anyone here have a cast iron reservoir on there Malibu or G Body???
I think most of the GM boosters have the same pattern. I also have a cast iron Vette disc/disc master.
TURNA
6,028
Socialist NY
did u change the bolt on the booster that connects to the Malibu pedal?
355_79bu
1,240
Cotter, AR
I have a Camaro cast iron disc/drum master on mine. Bolted right on. I am not sure about the booster. You could go to your local parts store and have them pull the booster you are in question about, measure the studs out, and compare to the Malibu holes.
TURNA
6,028
Socialist NY
the camaro master fit right on? do u have a single or double diafram booster? What year camaro master did you use?
Thanks!!!
TURNA
6,028
Socialist NY
and u have a 79 Malibu or 80? Thanks for your help!!
