Powerglide ???
RollinThunder
Member
Nov 12, 2011
8
Drumheller, AB. CANADA
OK all you glide experts! I have a few questions...
Just got my car (not complete) and it came with a glide that was (is) supposed to have a manual valve body and a brake. First off when I looked at the transmission, it had no electric solenoid sticking out of it... so I am assuming, no brake. It has been a looong time since I worked on a glide, did they not from stock have a kickdown lever that ran in through the shifter lever? This transmission doesn't, so again I assume... maybe it has had the valve body changed. Any thoughts??? If I pull the pan, can I tell somehow if it is a manual valve body?
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
to install an aftermarket cable type shifter on a glide you need to change the shift arm so thats probably what was done and if there is no wires then there is probably no brake. I think an aftermarket manual valve body would be machined steel and not have a cast appearance like a factory valve body. Also an aftermarket VB would probably have a reverse gear pattern
PRN12.
brian
BTW - how fast has your car gone before you got it? I noticed it had lots of gear ,4.56's..
RollinThunder
Member
Nov 12, 2011
8
Hi Brian
manual valve bodies can be bought forward or reverse pattern... and a lot are cast not machined... ATI lists valve bodies with external & internal brakes... so, still not sure.
RollinThunder
Member
Nov 12, 2011
8
and it has never been finnished, never on the track... my experience running glide as opposed to you running a 3 speed, u need the lower rear gear to get it off the line. I haven't raced for a lot of years... I ran a FED with a big block and glide, 410 gear 8 3/4", but it only weighed 1900 with me in it...
RollinThunder
Member
Nov 12, 2011
8
it will also be set up with taller slicks 31"... which in my experience, lower gear to get it off the line... taller tire, more MPH at top end.
