STARTING PROB
Helped my buddy put in a lq9 6.0 in his camaro and we put a vic jr intake on it and a msd box,everything is hooked up right and you have to crank this thing like 30 seconds before it will spark and start.called up msd and verified everything is right even hooked up the lap top on it check timing but for some reason it does this evrytime.could it be a bad box or has anyone else had this issue
Roller406Bu
396
Elizabethtown Ky
is it trying to start after you let go of the key? Make sure its getting 12 volt to the box while your cranking it...It maybe only getting it when your releasing the key....let me know how it goes...
455_82malibu
1,400
WISCONSIN
check spark when its cranking and see if its there right away also crank and cam sensor may have a intermitent short?
hey when we hooked this up to the laptop it showed 0 rpms while cranking is this right ,he put a new crank sens in it and still the same thing..you have to crank this thing for at least 35 seconds before it starts not (good on the starter)but once it fires it runs fine,revs right up idles fine just dont want to start back up
Roller406Bu
396
Elizabethtown Ky
it does this everytime? after it runs awhile and you shut it off it does the same thing?
yes it will not spark at all until after 30 seconds.it doesn't matter if it's sat a week or or right after you ran it
lurchsmalibu
3,774
Lakeland, Florida
What will it do if you turn the key to run position for 30 seconds and then try it? same thing??
How about oil pressure build up before starting?? safety feature?
lurchsmalibu
3,774
Lakeland, Florida
has the problem been resolved yet?
Update it turned out to be the cam sens.took it to the track wends this is a stock lq9 motor with eddy carb intake and 750 holly carb and headers in his 95 camaro it went a best of 11.73 at 113 mph slowest time was 12 flat in the first pass changed the rev limit it was set at 5500 so we turned it up to 7000 and it ran 4 pass's in the 11.70's not bad for a stock motor
