th350 or th350C
DFWMalibu
999
Dallas,Tx
How can you tell the difference.......
Chris K.
Z-man
1,058
Barnesville MN/ Fargo ND
A 350C will have a electrical connector on the drivers side just above the pan
Bar50
1,871
Tulsa, OK
If it is out, slide the convertor out, and the input shaft will have a polished end with an o-ring. A non-lock up, normal 350 or 375 will have splines only.
Unless someone has converted it to non-lockup by changing the shaft/pump and valve body at some time over the years. Then, it might have non-lockup internals and pump but lock-up case. Rare, but it does happen.
