TPiS ?
bonez305
49
Miami, FL
Anyone know anything about this TPiS Mini Ram setup ?
How I could get the most out of it ?
I have it on a 350
block number
14093638 350 86-88 2&4 Bolt Main HP 205+
don't know of any other mods on the motor other than the intake and some headers
They claim it's capable of up to 80hp more than a stock intake.
Is this it? http://tpis.com/parts/view/33
1.MAN550
You'll be able to tell more once/if you pull the distributor/valve covers. Is the engine in the car? If so it will be much easier to see down inside... if you pull the distributor and look down through the dizzy hole you may be able to see if it has a roller cam or not. You can likely get quite a bit from that intake with a good head/cam combo and some tuning.
More or less, especially if the current car didn't come with EFI and it was added after. In that case you can probably transfer everything over electrical-wise fairly easily. I want to go with an OE look on mine whenever I put EFI on it, so it won't be as simple.
bonez305
49
Miami, FL
I was thinking the same I would like to do a 6.0L/6.2L with an Intake and Throttle Body on top and some Holley LS Valve Covers to cover up the Coil Packs like the Holley Truck
6a00d83451b3c669e2014e602dd686970c-800wi
