Underhood wiring help needed .....
PA BU
288
Dallastown , Pa
This is a v-6 to v-8 conversion with HEI along with 1 wire alt. and battery relocation in trunk with kill switch .... so I have all these wires under the hood that I'm not sure what to do with (everything on the pass. side of the plug on firewall)...... all the reds and 2 browns that went to the alt. and starter and a couple of other browns and greens and some going to a funky round plug ... the only wire I figured out was the brown ing. wire going to the starter ...... do the 2 reds that come out of the plug that eventually go to alt. and starter need to go to the battery ??? Are they what power all the lights and instrument ?? the small brown wire that went to the alt. plug shouldn't be needed anymore with the 1 wire conversion .. correct ?? and the others I'm assuming went to the heat and a/c stuff that was gone ......
Any help guys ??
Goob
3,641
Indianapolis
http://www.maliburacing.com/forum/viewtopic.php?f=27&t=41117
