Upgrading Braks
axisg
407
YYZ ( Toronto )
IIRC the 90's AKA LT1 rear rotors were 11.5", the 98-03 AKA LS1 rear rotors are 12".
Clearance for 15" rims only comes into play with the rear brakes. The fronts ( if using the Blazer setup ) should clear 15"s
Loads of great reading over at 3rd gen or google ls1 rear brake swap
axisg
407
YYZ ( Toronto )
the s10 is the same as the stock gbody at IIRC 10.5 using hub and rotor on spindle with a single piston caliper.
The 98-03 2wd blazer uses a sealed hub bearing, 11" rotor, and twin piston caliper.
Not much more surface area vs stock but the twin piston caliper should produce more clamping force
