vacuum distributor or non vacuum
dave
13
Napanee, Ont
my old 406 30 over cast dish pistons small cam 327 heads air gap intake hp750 carb stock plugs gap at 35 1-5/8 headers coan 2800 stall 9 inch 370 gears 275 drag radial I run a stock vacuum gm distributor with a 125 shot plate timing set at 10 degree base and run 113 gas it worked good my new 406 30 over 11.1 wiseco forged pistons lunati 560/565 roller hyd cam dart shp aluminum heads 64cc 200cc runners 202/160 valves same intake and carb with a 175 shot plate same gears and a hughes 3500hd stall so what is better for new motor a vacuum msd distributor or non vacuum one and should I set up my header size to 1-3/4 or keep the 1-5/8 do drive a bit on the street any help would be great happy new year to everyone
I'd never run anything other than a full drag-only car without it...
You're welcome!
