From moroso insturctions:
"Determine the Inlet from the instructions above and plumb a hose to the valve cover using a –12AN
fitting. DO NOT use a catch can between this hose to the valve cover.
Plumb the Outlet side of the Pump to a Breather Tank, such as Moroso p/n 85465."
SS402 said:
Does this eliminate trash getting in the pump?? I've seen vc to pump to catchcan/vent. <<<is that Ok or just not the best way?? Too bad I can't afford the Star electric one.
I am planning on using one of the -12 baffled fittings on the front of the valve cover.
Isn't it good to have some oil mist sucked up by the pump for lubrication, then it expels it into the catch can on the outlet side?
