Vacuum Question(s)
G-boz
701
CT
www.ctgbody.com
Im running a Victor Jr intake with a Comp 292H cam and Im having trouble with my Power brakes. The Vic Jr doesnt have a vac port so Im pulling it off the carb, but still have weak brakes.
Just wondering if anyone else is running a similar setup and what can be done. Do I need to install a Vacuum pump/cansiter?
If you're pulling less than 14" Hg at idle you're going to have problems. Most manufacturers say power brakes won't work right with less than 16". Try a vacuum reservoir with a check valve in the line from the carb, just like on the booster.
I can't gaurantee it, but it's a cheap thing to try.
malibu795
1,497
4
spgfd ohio
244/244@ .050 and a 110LSA you idle vacum is prett low..
im runing a 234/244 @ .050 112LSA and hit 13-14" when warm at 850-900rpm
malibu795
1,497
4
spgfd ohio
i use a 3/8" barb fiting off the back side of my edelbrock carb and run it straight to the MC booster
The port on the carb should be fine. I'm with Tommy & trying a vacuum reservoir if you don't want to change the engine combo. Far as vacuum rising/falling, there isn't any vacuum on acceleration, only time you would have vacuum is at cruise for the most part. You will also get a little extra on deceleration because the engine is under less of a load, and may actually be 'pushed' by the weight of the car if equipped with a manual, or the inertia of the torque converter if an auto is used.
