I want to run 15x8" Weld Draglight's in the rear of my 79 BU and am not sure of what offset I will need to order, can someone help me out. I also want to run 28x10x15 slicks if possible, I have cut and folded the inside lip of the fender wells and want to know if they will fit with no problems. If they won't, then what size do I need to run to get the most tire to the ground? The rear-end is stock size with a posi. Thank you if anyone can help....Irish
