Why the 86-93 8.8" in the G-body?
Memphis
30
From all the links from this site, all the threads, and other sources people talk about running the 8.8" axles from 86-93 Mustangs. BUT The Mustang rearend is only 57" wide! On cars that crowd the rim/tire towards the frame why run a rearend locating the rim 1/2" closer to the frame?
The resources I've found list the G-body rearends @ 58"
The 94-98 Mustang rearends are listed as 58.5" wide. Wouldn't it be better to have an additional 1/4" of space away from the frame?
If you could find a 66-77 Ford Bronco rearend 9" it lists at 58" wide the same as the G-body.
Any info on the Mustang rearends from the 94-98? Or did the factory make them weaker? JD
P.S. Now I'm more confused as I found two new websites that say the 86-93 Mustang 8.8" are 58.75"! Gees which is it 57" or 58.75"?
Also, I found more info on the 94-98 and they range between 60.5-61.5" wth
SSedan64
948
MACON, GA.
Good ole internet Info, gotta luv it. :roll:
More 9" Info> http://carnut.com/specs/rear.html these are WMS to WMS or Drum to Drum.
I'm not sure about the 8.8" widths. http://www.google.com/search?hl=en&source=hp&biw=1003&bih=619&q=8.8+mustang+rear+end+width&oq=8.8%22+mustang+&aq=2&aqi=g3g-v7&aql=t&gs_sm=c&gs_upl=1875l8000l0l13l12l0l0l0l0l328l2829l0.3.7.2l12 have at it. :shock:
