WIRE PROBLEM?
BIGB197480
54
3
8
PEORIA ,ILLINOIS
I HAD MY HARNESS OUT OF MY 79 BU.NOW THAT I HAVE IT IN WHEN I TURN MY LIGHTS ON MY GAS GUAGE QUITS,MY TEMP GUAGE BURIES PAST 220 ANY IDEA WHAT I FORGOT TO HOOK UP? THANKS
toxicbu
616
romeoville il
check all grounds , the more the better
Ground :D Most likely the power for the cluster. Make sure all 4 nuts that hold the cluster in place are tight, and the connection between the cluster and its harness is clean. Follow all black wires from that plug and make sure they're grounded well. I did this and it stopped all but minuscule gauge movement when I turned the lights on. The illumination circuit on the cluster has to find a ground somewhere, and consequently goes from the bulb to the ground... but since there isn't a good one it cycles back up through the ground for the gauges, and grounds through the gauges, and ultimately the sending unit and whatever it's grounded to.
