I am looking for some help and fiqured some other stuff out with help from lester . what about these :
I thought the defrost delay connected to this but mine don't match up to the plug style , what plugs in here ?
Next one goes off from the steering wheel area but where does this end plug to.?
These are hooked up but what are they for ( 3 wires plug in it , brown , blue , black ) i don't have door light ot buzzers . if that whatthey for .
When using after market gauges i can unplug the main instument plug and use the wires listed inthe Faqs section , can remove the ones i need , like turn signal and can use the light one for the hot on the new gauge lights . Do i use the ground from the main plug that goes into the instrument panel also and just block oft the rest ?
last one for now .. The brake switch that goes in where the pedel is has 2 plug ends on it , does only one get used ?
Thanks
Thanks
