Would these fit?
zdeckich
233
Fort Worth, Texas
Ok im new to the Malibu scen, i seen a few things saying the bolt pattern is 5x4.75 with a 4 inch back spacing. and i found some rims i like and would like to know if i could run these on all 4 corners?
Yup, generally you can run up to about 4.75" backspacing if you need that much, if your rear bushings are all good you can probably go to 4.875", but will need a stiffer sidewall (i.e. 17" wheels, etc.). I had a set of 17x9.5 under the rear of mine at 4.875" bs and it would've only needed a lip roll/trim to fit just fine.
A 7" rear rim is really going to limit you on tire size.
zdeckich
233
Fort Worth, Texas
ok thanks again for the help. is there a tires size you reccomend? im also wanting to lower it about 2 inch in the rear.
Similar threads
