1/4 mile results....chinese turbo.
455_82malibu
1,400
WISCONSIN
smells like fried rice,,,but it works...lol
Ran the car and got some times on the chinese turbo. Ran great but had to let off cause the 3.42 gears were too low..
L33 alum 5.3. ls6 cam springs
factory fuel injected >>> stock truck MAF
9-10 psi
1.7 60 foot.....footbraking
6.9 1/8th mile
105 mph
10.6 1/4th mile
128 mph
LSJM1
134
Atlanta
awesum how much boost can you build on the foot brake I had the bigger wheel cylinders and long shoes on my GN with pushing as hard as I could on the petal I couls leave the line with 20 psi
455_82malibu
1,400
WISCONSIN
well I have the lower control arm lift brackets, so when I give it gas the whole car raises and then i start pushing through the front brakes, the rears must not be adjusted tight enough, I think its on the verge of building boost but then I start to creep forward.
LSJM1
134
Atlanta
If you have the G-body 8.5 rear try some 7/8 wheel cylinders from a mid 80's manual brake s-10 part # 33892 at autozone and get the cheapest organic material shoes-get 2 boxes so you can use the long secondary shoe in the front too
I'm assuming you have a line lock if not you will heat up your rear brakes and it won't lock down good even with the bigger wheel cylinders and long shoes
I could cut 1.45 60ft's all day long only suspension mods were air bag in the right spring at 30psi and no front sway bar on 28x 10.5 M/T slicks
1.45 60 ft on your car you could see some 10.20's
455_82malibu
1,400
WISCONSIN
Good tips. I will try that. And no I don't have a line lock. I don't have a front sway bar, and I have an airbag in the right rear
Al
2,018
Harker Heights, TX
That's with a single cheap turbo on a basically stock 5.3? Pretty nice. I'm surprised the gears were too low. What tire size are you running?
455_82malibu
1,400
WISCONSIN
Motor has a gm zo6 cam. I shift at 5500. I go into 3rd before the 1/8th mile. So between the small 26" tire and converter slip the car wasn't pulling anymore. Was making weird noise so I assume the valvesprings were floating also.
