Th350 low /reverse clutches
Moderator: Moderators
Post Reply
BillJ
Post by BillJ » Sun Mar 29, 2015 4:19 pm
Pulled apart my th350 with a brake and everything looks good until I get to the low reverse clutches they were welded together. What would have caused this and how do I prevent it from happening again. I also sent my torque converter in to have it checked out and they found the sprag was broken are these too things related. The trans worked fine in reverse but when you shifted from first to second it locked up the tires. Any help would be great. Thanks
Pete@Hughes
MalibuRacing Authorized Advertiser
Re: Th350 low /reverse clutches
Post by Pete@Hughes » Mon Apr 06, 2015 6:29 pm
This could be caused by a number of reasons, including bumping the transbrake button when the car is in motion, a problem with the piston in the back of the case, a crack in the case, a cut lip seal, insufficient clearance in the clutch pack, etc. A welded reverse clutch pack is typically a very uncommon problem with a TH350.
Pete Nichols
Sales Manager / Tech Support
800-274-7223, ext. 209
602-889-3621
pete_n@hughesperformance.com
http://www.hughesperformance.com" onclick="window.open(this.href);return false;
BillJ
Post by BillJ » Tue Apr 07, 2015 1:50 pm
thanks
Post Reply
