Th350 pump thrust washer / bearing
Moderator: Moderators
Post Reply
BillJ
Post by BillJ » Sun Apr 05, 2015 7:38 pm
Just another question with my rebuild. Used the Hughes rebuild kit and it is a good kit. My question is. When I checked end play before the rebuild their was 0 end play. Installing the pump after rebuild and replaced the torrington bearing with a new one I had 0 end play. Can you just use a new thrust washer in the place of the bearing. How do you know if the pump is machined for a bearing. There is Torrington bearings in the trans do you have to use a bearing under the pump. Please help needed to finish trans. Thanks
Pete@Hughes
Re: Th350 pump thrust washer / bearing
Post by Pete@Hughes » Mon Apr 06, 2015 6:31 pm
Yes, you can replace the bearing with a thrust washer in order to achieve proper end-play in the TH350. You may have to shim the washer accordingly.
Pete Nichols
Sales Manager / Tech Support
800-274-7223, ext. 209
602-889-3621
pete_n@hughesperformance.com
http://www.hughesperformance.com" onclick="window.open(this.href);return false;
BillJ
Post by BillJ » Tue Apr 07, 2015 1:49 pm
Thank you
Post Reply
