what 3.8 do i have
Info and tech for V6 engines
Moderator: Moderators
Post Reply
dragonmaster093
what 3.8 do i have
Post by dragonmaster093 » Wed Sep 21, 2011 6:25 pm
its factory in my 79 cutty wagon has front distrbutor on the drivers side. need to know since thinking of cam intake swap dont know if even or od fire for ordering a cam. im sure valve cover dont much matter but look like a sbc just smaller
DOUG213XRJ
Re: what 3.8 do i have
Post by DOUG213XRJ » Wed Sep 21, 2011 10:56 pm
Its a Buick 3.8 L 231 C.I .
Doug
1978 El camino
1981 Malibu SS
dragonmaster093
Post by dragonmaster093 » Wed Sep 28, 2011 12:39 pm
is thar even or odd fire for when i order a cam?
DOUG213XRJ
Post by DOUG213XRJ » Wed Sep 28, 2011 3:05 pm
Even-fire.
Doug
1978 El camino
1981 Malibu SS
dragonmaster093
Post by dragonmaster093 » Thu Oct 06, 2011 2:09 pm
will the trans bell housing be ( hope hope) uni patern or bop or chevy. got a 305 i can put in as long as i dont have to replace trans thanks
DOUG213XRJ
Post by DOUG213XRJ » Thu Oct 06, 2011 7:15 pm
dragonmaster093 wrote:will the trans bell housing be ( hope hope) uni patern or bop or chevy. got a 305 i can put in as long as i dont have to replace trans thanks
You can check the transmission for a dual bolt pattern, But I wouldnt count on it.
Doug
1978 El camino
1981 Malibu SS
80ECLT
V6 Guru
Post by 80ECLT » Wed Feb 08, 2012 2:45 pm
I think the factory 1979 trans for a V6 231 will be BOP pattern only. the later models had dual patterns.
"El Camino's Unlimited" Sheboygan Falls, WI 53085
1980 El Camino "LT" 4.3 Liter Vortec, Saginaw 4-Speed
The worlds first and only, therefore fastest L35 G-Body!!
"He drives an El Freakin' Camino! That's like the Cadillac of cars!"
dragonmaster093
Post by dragonmaster093 » Sat May 19, 2012 10:43 pm
whats the best parts to wake up this lil sucker? what carb can i use in place of the dual jet thats on it? its that few yrs only (that ive found) 1/2 a quadra jet. seems like it was a v6 only carb and didnt stick around long there are rebuild kits for it but due to odd shape an after market air cleaner has to have a hard to find adapter. if an other carb like carter or holley 2 barrel carb will bolt on that would be good
dragonmaster093
Post by dragonmaster093 » Wed May 23, 2012 10:00 am
anyone
Darwinskeeper
Post by Darwinskeeper » Fri May 25, 2012 4:14 pm
Sorry, but like most of the people on this board I really have no experience with normally aspirated Buick V6s. In my case, I have a lightly modified Chevy 4.3 V6 (3/4 of a Chevy 350) in Darwin and a tired, stock Chevy 3.8 (229) in White Lightning.
I'd imagine that the basic mods I used on Darwin, a small 4bbl carb, a dual plane intake manifold, mild head cleanup, a mild camshaft, headers and a dual exhaust would help, but I have no clue as to the specifics for the Buick V6.
You might use the browser of your choice and see what's out there for the Buick V6. I did a little looking awhile back and most of the info I found was for the odd-fire Dauntless 225 that was used on Jeeps.
John E.
"All middle aged men are pigs," Porco Rosso
Darwin, a 1979 Malibu Wagon with a 3 speed Manual box and 2.41 gears in back
Engine is a '85 4.3 V6 topped by an Edelbrock Performer and a 465cfm Holley 4160. The heads have a 3 angle valve job and the cam is a Crower Level 1 240HDP grind with Comp Magnum 1.52/1.60 rocker arms. Full headers with 1 1/2 primaries dump into duals with 2 1/2 tubes and turbomufflers.
toyodajeff
Post by toyodajeff » Sat May 26, 2012 8:52 am
I used to have a dualjet on my v6. It had the d shape air cleaner opening. the stock filter was about 9 7/8 inches diameter. If you cut out the air cleaner bottom around the air filter base you can run whatever 10 inch chrome top you want. It looks like the open element filters you buy.
80Grand_LeMans
Post by 80Grand_LeMans » Sat May 26, 2012 9:09 am
GN turbo swap?
1980 Pontiac Grand LeMans
-Mild Olds 350, TH350, 7.5 one tire fire :(
bukweet
Post by bukweet » Tue Sep 25, 2012 6:46 am
If you can find a late 70's early 80's Big body Buick with the 252 V6, you just might find a 4 bbl intake that will also fit the 231.
Factory and heavy but a 4 bbl none the less.
Edelbrock used to have a cam/intake package for this engine as well.
8)
bukweet
" Backyard Bonneville Longroof "
SOLD
Livin' for Him 'cause He died for me.
Artificial intelligence is no match for natural stupidity.
Post by LS6 Tommy » Sat Sep 29, 2012 8:32 am
dragonmaster093 wrote:its factory in my 79 cutty wagon has front distrbutor on the drivers side. need to know since thinking of cam intake swap dont know if even or od fire for ordering a cam. im sure valve cover dont much matter but look like a sbc just smaller
Well, the front distributor tells me Buick 231. The valve cover description sounds like Chevy 229, but it can't be with a front distributor, so Buick it is... All 78+ Buick 3.8's are even fire.
Post Reply
