so, gonna do my top end rebuild in a few weeks once i get some tools and odds and ends.
so, first. im using head studs. do i use thread sealer when i screw them into the block? and then use oil on the threads where the nut goes?
since im running a solid roller, what do i use for a break in lube on the cam? do i need any? im also running a mech fuel pump.
also, can i get by with a stamped steel timing cover, or should i switch to a cast aluminum one? (regarding camshaft end play)
im sure i'll think of more down the road too. thanks!
