monte ss steering box into malibu...
I'm pretty sure you'll need to change the lines or get adapters. IDK what box you have now, but if it's a "four bolt" (Saginaw 700) power box, other than the hoses fittings it's a bolt-in.
78FLMalibu
60
Montverde, FL
www.cruizers.org
I'm not sure...its on the 78...but nothing yet has been original...
Here's a pic of whats there now...
And from the Monte SS...
Shawn
They're both 700 boxes, but IIRC, the fittings changed in 1980. I think you can get adapters to go from inverted flare to o-ring.
4,700
32
1979 might be the start of the metric boxes, I am not certain either. If your box has a stem sticking out of the input shaft like the MCSS box, you may be lucky. If not, you may need to replace the lines.
