Need help with 12 bolt rear
81malibu355
224
Hamilton, NJ
Hey guys. I need some help indentifying my 12 bolt rear. I know thcasting number I found on the webbing apparently is from a 69 Chevelle. But I can't determine whether it's a 3 or 4 series carrier. Any help would be great!!
I only found 2 numbers.
The casting number I found was 3959038
The other number I found was- M1 D N
I will try to upload pictures but it won't let me from my phone
Edit. Here are the pics
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
I would say then that its a 4 series carrier unless it has the special richmond "thick gears" which you should be able to identify by the part number on them.
brian
SSedan64
948
MACON, GA.
Car 12-Bolt 3-Series carrier allows 3.08 - 3.73 ratio stock gears, + 3.90, 4.10, 4.56 & 4.88 Aftermarket.
Car """""""""" 4-Series """""""" """""""" 4.10 & up stock ratio, + 3.73 Aftermarket.
Truck 12-Bolt 3-Series carrier allows 2.76 - 3.42 ratio stock gears, + 3.73, 4.10 & 4.56 Aftermarket.
""""""" """""""""" 4-Series """"""""" """""""" 3.73 & Up.
SSedan64
948
MACON, GA.
The Housing numbers you listed wont tell you if it's a 3 or 4-Series carrier.
3.73 gears are available for 3 & 4 Series carriers.
You'll have to look a the Stamped part #'s on the Ring gear or Casting #'s on the Carrier.
Eaton Posi's 12-Bolt Carrier casting #'s:
2-Seires = ED32088
3-Series = 30140PM1
4-Series = EDB30174
There're Stamped #'s on the passenger side Axle tube that indicate stock/oem axle ratio. Pic below.
