    Automatic Transmission Identification and Information
    (Everything you wanted to know and keep asking!)
    Gear Ratios of Popular GM Transmissions
    Trans1st Gear2nd Gear3rd Gear4th GearReverse
    Powerglide1.76/1.821.00——1.76/1.82
    TH3502.521.521.00—1.94
    TH4002.481.481.00—2.07
    TH200-4R2.741.571.000.672.06
    TH700-R43.061.621.000.702.29
    4L80E2.431.491.000.752.07
    Transmission Guidelines
    Transmission Dimensions
    Transmission Identification By Pan
    1Aluminum Powerglide14 bolts
    2TH200 Metric11 bolts
    3TH35013 bolts
    4TH40013 bolts
    5TH200-4R16 bolts
    6TH700-R4, 4L60, 4L60E16 bolts
    74L80E17 bolts
    Identifying a TH200-4R vs. TH200
    Photo of TH200-4R transmission
    The TH200-4R is identified by 10 bolt holes and 2 dowel-pin locator holes on the universal bellhousing.  It has a dual bolt pattern for both Chevrolet and BOP (Buick, Olds, Pontiac) applications.  The TH200 has only six bolt holes and 2 dowel-pin holes.
    • An error has occurred, which probably means the feed is down. Try again later.
