15-10 rear wheels
ghostrider
32
perth amboy nj
hi i just got a set of rims for my 80 malibu it has a ford 9in fronts are 15x4 1.75 bs and the rears are 15x10 4.5 bs im planning to notch the frame and roll the lip on the quarters trying to fit a fat tire in the back any suggestions or ideas if anyone has pics that they can share also gonna put a anti roll bar thx
prairiehotrodder
1,560
Melfort Saskatchewan Canada
if the ford 9'" rearend you are using is stock width for a g-body then you will need 15 x 10 wheels with 5.5" back spacing if you want to "tuck in" a big tire. I'm using a MT ET Drag 29.5 x 10.5 with that wheel combo. It also requires a full frame notch.
You could use a shorter tire that will hang out in the wind on those rims you have. I think they will still be really close to the frame on the inside without a frame notch.
Brian
