I want to run a the same wheels, but would like to run 17x9.5's all around if I can.
You might consider a 245/45 up front, that keeps the overall height of the tire the same front and rear, unless you're wanting a shorter/narrower tire up front. The 245 should mount on an 8" wheel, since they do it on 16x8's all day long, so you should be ok there.
You may also look on http://www.pro-touring.com for the answer to this question. I haven't been able to get the answer to mine (since I'm running a Cutlass), but you may have better luck.
I will be ordering one of those wheel-rites or whatever you call it and measuring it that way I guess, to see what I can fit, once I get the new rear and stuff in the car.
Good luck, I'm going to keep an eye on this thread, and let me know if you post on Pro-Touring, so I can keep up with that thread over there too.
I hear that 5" backspacing in the back and 4.5" in the front is the norm, but don't quote me, maybe that will get you close? I think it has to do with the way the frame kicks out behind the rear wheels or something?
