15 x 10 fitment questions
86olds4spd
28
south western pa
Does anyone know if a set of 15 x 10s will fit under a g body rear ? I'm not worried about backspacing I can have it changed. I was woundering about them fitting between frame and quarter panel. If so any wheel/tire combo suggestions?
tyster89
979
North of ST Louis MO 30 miles
I seen Spraydn60's bu at the track last Sat. He runs a 15x10. Notched frame , but stock tubs, and rolled lip. Fills it up thats for sure. I couldn't believe how much the tire changed on a 10 compared to a 8. We both run a 275/60 radial, but mines an 8' wide wheel. I've been searching for a 15x10 with a 12 bolt swap(1970).
86olds4spd
28
south western pa
That is kinda what im planning. I found a ford 9 inch that measures 60" wheel mount to mount. My factery rear is 58". The wheel i'm looking at has a backspace of 5"
malibulvr
1,929
Pensacola, Fl. 32526
I haven't gone to a 10" wheel yet but I am planning to. I have a Chevelle 12- bolt, which is approx 2" wider than my stock rear end, with 5" b.s. 15 X 8.5 wheel and 26 X 11.50 X 15 E.T. Streets. My car is a little lower than stock but my tires hit the rear fenders. By my measurements, the perfect wheel is going to be a 6.5" b.s. 15 X 10 with a full rear notch and mini-tub. Thats the only way I can see a 10" wide wheel working without the rear end pointing to the sky or the rear tires protruding past the fenders. Good luck with it.
rich
1,226
kenniwick wa.
i have a 15 x 10 6.5 bs on a stock frame lip rolled with 28x 10.5 m/t moroso rear trick springs
also have a set of pro stars 15 x 10 6.5bs in great shape drilled for screws
Olds80Six
125
Westmont, IL
I have 15x10's with 4x5" backspacing, 275-60-15 M/T radials.
There is a stock width Moser housing under there, the only thing I did was roll the fender lips.
I have about 3/8" clearance from the frame.
