My aunt has a '98 AWD Safari. The front end always feels like it's binding/front diff is locked when the wheels are turned... long as I can remember it's always done this. Is it normal?
axisg said:Are you sure it's the front end. My '03 used to bind at what I thought was the rear going around corners or in the parking lot. Turned out to be the transfer case
I did some surfing and joined http://www.astrosafarivans.comparts for gmc Turned out there is a TSB on the AWD vans to swap out to a newer type transfer case fluid. I followed the procedure, updated the fluid, and the binding is gone.
