200-4r shifting problems
jking78
59
I install 200-4r with b&m ratchet shifter. I cant manually shift into 2nd and when in drive it wont shift into 2nd unless i let off the gas. Any ideas plz plz help.
SSedan64
948
MACON, GA.
The Manual shift problem is probably a Cable bind or adjustment problem.
The Auto shift problem sounds like the TV/ThrottleValve Cable is too tight.
Also, if you're running an aftermarket Carb, Holley, Demon or Edelbrock you need a Geometry Corrector Bracket on the Carb's linkage for the TV Cable.
Holley/Demon >> http://www.summitracing.com/parts/SUM-700202/
Eddy >> http://www.summitracing.com/parts/SUM-700203/
TV & TV Cable Info:
3-Parts >> http://www.tvmadeez.com/article/index.php
http://www.jakesperformance.com/TV_Cable_Setup_Info.html
jking78
59
OK I adjusted the TV cable again. 1st & 2nd good 3rd boggs real bad until I go a certain speed but still no passing gear.
SSedan64
948
MACON, GA.
Cable may be slightly too loose if no passing gear. TV plunger in Valvebody could also be sticking/binding.
You should use a Pressure Gauge to set it if possible. Also checked while driving/shifting.
