2004 Cadillac transmission cooler thermostat placement?
78elk
1,294
81
Mountain Home Id
No I'm not running a temperature gauge on the transmission. I was told the thermostat would get the transmission fluid to a temperature, that is better for it in cool weather. I forgot to mention that I tried draining the transmission fluid at new thermostat. I disconnected 1 hose off of the thermostat, thinking the thermostat would be closed, because the oil wouldn't be warm. But I was wrong, oil came out of the thermostat as well as the hose from the transmission cooler. I had a mess to clean up. So apparently it didn't work like I thought it would.
melloelky
3,654
31
mass
stuff like that/trial and error is all part of hot rodding.we've all been there.don't know unless you tried right..
  • Like
Reactions: 78elk
78elk
1,294
81
Mountain Home Id
Correct. That's how I have learned on this Elk. I fixed mistakes made by people I hired. This was supposed to happen so I could learn to fix it and make it better. Thank you much for your comments and help.
  • Like
Reactions: melloelky
