275/60/15s on a 7" rim?
Smokes
356
S.W. Mo.
Is it doable? I know 255/60/15s will fit good, but i'm wanting that extra height & width, Also, will they clear on a 78 cutlass stock wheel well? Any pics would be great.
HOLY TERROR-BU
2,503
WATERBURY, CT
I THINK WICKED6 ON HERE, GOT THAT SAME TIRE COMBO ON THE REAR OF HIS BU. ASK HIM!!
468malibu
425
Binghamton NY
It will be a little narrow, tread probly wear funny. Also in less you run a spacer the tire might rub on the inside. Buddy tried a 255 on a stock wheel and rubbed...
If a 255 is rubbing on a factory wheel, it must have some sort of weird offset...
Al
2,018
Harker Heights, TX
I've run the 275/60/15 on 7 inch wheels for decades on several different cars. It works fine.
Smokes
356
S.W. Mo.
Now the big question, will the 275s clear in my 78 cutty stock wheelwell?
Al
2,018
Harker Heights, TX
If it's like the Malibu and El Camino it should fit with the right backspace. You might have to roll the wheel opening.
468malibu
425
Binghamton NY
Should fit fine, even room to spare. The Cutlass's have a larger wheel opening than Bu's and Camino's. I have 295/50 on 8" wheel and clears.
