355 / 377/406
DL
49
AURORA MO
which would be a better nos engine using a dart block on the 377 or 406 im currently running a 355 with a plate system will proble send my intake off to add a fogger set up and keep my plate as well need ur imput guys thanx
bowtie81
5,008
sarnia, ontario canada
theres no replacement for displacement, if your gonna use a dart block i would go with a 406. more cubes, strong build
DL
49
AURORA MO
r all nos pistons put the pin hole in the groove of the bottom ring
DL
49
AURORA MO
which block the dart little M or the sportsman block theres only 500 bucks between them can the sportsman be bored as much as the little M ?
and dyno flow in nevada priced me a shortblock
DART SPORTSMAN BLOCK ?? should i use the little m block
JE PRO SERIES NOS PISTONS
TNT TOTAL SEAL RINGS
EAGLE 4340 CRANK
EAGLE H-BEAM RODS 2000 PSI BOLTS
DURABOND CAM BEARINGS
BALANCED
ASSEMBLED
4,199 WHAT DO U GUYS THINK
Bigblockguy
195
ste Anne mb Canada
That's a good price. How much are you going to spray?. Go on http://www.yellowbullet.com
in the nitrous section they can help you out getting the jet spread right with a plate and fogger combo.
DL
49
AURORA MO
ILL SEND MY SUPER VICTOR TO STEEVE JOHNSON ON YELLOW BULLET HE WILL INSTALL HIS FOGGER BLUEPRINT IT AND THREE TUNE UPS 4 1600.00
DYNO FLOW SAID THE SPORTSMAN BLOCK WOULD HANDLE A 400 HUNDRED SHOT IM SPRAYING 300 ON MY 350 BLOCK KNOW
DL
49
AURORA MO
or big block guys need some input :x
eldabo
1,811
Mobile,Alabama
Im going to run my dart 406 with a 300 shot .I think it would be good with a lot more than that.
David
