4 wheel disc master cylinder
80ECLT
3,927
Sheboygan Falls, Wisconsin
I did a 4 wheel disc conversion and put in all new lines from inline tube. I also installed a Disc/disc combination valve as well.
What are you guys running for bolt on 4 wheel dics master cylinders?
Ws6 etc?
It like it to have the same thread sizes as the stock master so I dont have ro redo my new lines.
Any ideas?
abigda
616
Springfield, MA
Im running a C3 corvette 4 disc master, direct bolt on. Same fittings
80ECLT
3,927
Thank you for that info!
As a note< id prefer the body to be aluminum with a plastic resivor if possible.
abigda
616
Springfield, MA
It heard of some guys running a early 80's Cadillac elderado which is aluminum with plastic reservoir
80ECLT
3,927
I looked up one for an 84 eldo. looks liek it will work but it has a huge bore diameter compaired to the g body unit.
I just do not like the looks of the case resivor units with metal lid and bail. I like the alum and plastic ones they weigh half of the cast ones.
I'm also running C3 Vette iron master. In any event if you're running power brakes, you want a master with a 1 1/8" bore.
Malibu Monte
So what is the concensus on this? I want exactly what 80ELCT was asking for. Is the caddy eldarado the best bet?
