I found a cam which requires 5k stall, 11.5:1 compression.How does this one sound? Check out the specs:
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 4,500-7,500
Intake Duration at 050 inch Lift: 276
Exhaust Duration at 050 inch Lift: 284
Duration at 050 inch Lift: 276 int./284 exh.
Advertised Intake Duration: 313
Advertised Exhaust Duration: 322
Advertised Duration: 313 int./322 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.660 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.630 in.
Valve Lift with Factory Rocker Arm Ratio: 0.660 int./0.630 exh. lift
Lobe Separation (degrees): 106
