5 Speed Question
BIGB197480
54
3
8
PEORIA ,ILLINOIS
got a chance to grab a 5 speed out of a 89 rs camaro 5.0 high output for a hundred bucks.is it better than my saginaw?what am i gonna have to change?any help would be great.this is still my project,not driven yet,has a well built 350/350 horse.street use only.oops, its goin in a 80 malibu.thanks.also how do i id. this 5 speed.wanna make sure its out of what the guy says it is.
4,770
39
If it is original to the car, it should be a World Class T5. To properly ID the transmission, I suggest looking at a few websites:
http://garage-scene.com/t5-into-ag-body/ (look for the chapter on identifying marks)
http://www.5speeds.com/t5/index.html
The items to look for:
The front cluster bearing is a Timken bearing, not a Torrington bearing
The input shaft is 26 spline, not 14 spline
Check the 1st gear ratio to be sure it is 2.95:1, not 3.5, 3.7, or 4.0:1
Check to see if the input shaft is tight or if it wobbles (bad bearing or needs reshimming)
There is not much more you can look at from the outside.
If these points are true, than for $100, you are getting a good deal.
Will it be stronger than your Saginaw? No, they are about equal in strength, depending upon the 1st gear in your Saginaw.
