5 speed trans question
clean8485
91
I have a 1981 Iraqi Malibu with the 3 speed Saginaw manual transmission. Does anyone here know if there is a newer GM 5 speed transmission that will allow me to keep the shifter in the same location as it is with the 3 speed? I'm wondering if maybe there is an S10 5 speed with the same shifter dimensions as the 3 speed. Thanks in advance.
TURNA
6,028
Socialist NY
You may be able to use a T-5 with an S-10 shifter loction and an offset shifter.
My old Malibu had a Camaro T-5 with a S-10 tailshaft.
Came out in almost the same location but centered on the hump.
So with an offset shifter you might be able to do it.
clean8485
91
Turna, thanks for your response, and thanks for posting the photo. That's pretty much the situation that I'm hoping for. I'm wondering if I could install a 5 speed and keep the bench seat in the car.
TURNA
6,028
Socialist NY
Yes you can if you have the S-10 tail
A Camaro tail will set the shifter to far back.
