6.0 on the dyno....
455_82malibu
1,400
WISCONSIN
finally got a chance to run the car, this is a stock truck 75mm TB-intake, small .540" cam, headers , zex (made 80hp at the wheels) 2.5" cheap thrush turbo mufflers. max timing was locked out at 24 degrees. untuned and very rich.
78Bu88SS
1,241
Cape Cod, MA
What were the numbers?
455_82malibu
1,400
WISCONSIN
lets just say over 400+ hp, 400+Tq...
Im not sure the dyno was right, there were a few cars with really low numbers...like a newer GTO, it put down a best of 260 rwhp...which I know is way low.
78Bu88SS
1,241
Cape Cod, MA
Was that NA or w/ the bottle? Car sound gooded man, I'm hoping to have my swap done by th 4th.
59RAT
317
Port Saint Lucie Fl.
455_82malibu said:
bottle, i had jets for 125rwhp in but it only added 80 hp!
Some of the jetting tune ups they give you are way rich and you will only get so much out of them till you lean out the fuel jet. Did you check Air/Fuel mix? This will tell you if the tune was rich or not. I used the NOS tune for 125hp shot once and only got 83rwhp, way rich on the A/F. Squared the fuel jets with NOS jets and got 118rwhp. Just a thought, but I know they tend to give very rich tune ups in the paper work. Rod
59RAT
317
455_82malibu said:
the jets were for 140+ motor HP and 125 rwhp...not 125 jets
This says that it was even more off. What were the jets? What was the spread?What was the bottle pressure?
455_82malibu
1,400
WISCONSIN
57/32 on a single nozzle. 950 psi. 55psi fuel pressure. Im thinkign the dyno was 40 off
MY FYN 79
487
N/E WI
Car sounded good, but I'm not sure I understand why we need to play the guessing game on its output.
