6.0L
JBLAZER
118
Ok i took the 355 out of my 85s10 blazer and im going to put in a 6.0l.i do know quit a bit about the motors cause im around them but im looking for pics of 1st gen s10s with the ls base motor with a carb.the motor i pulled out ran good it was a 355 with rpm heads and would run 8.0s to 7.90s on motor and 7.20s on a 135 shot.so if anyone has pics or anything that i could go by please post them.Thanx Joey
JBLAZER
118
and i know i have to notch the front cross member for oil pan clearence.this will be a cam and carb only setup so it should run better then my old setup by far.and i here people say that you can use your converter that you already have but you need a spacer.i dont want to get rid of my converter cause i like it it makes me happy.lol.so where do you get the spacer needed and i am going to be running my exsisting t350 cause i like it and i have to much money in it to want a different transmission.Joey
T5MalibuWagon
1,386
Fort Worthless TEXAS!
http://www.maliburacing.com/forum/viewtopic.php?t=59225
Might help
wgnguy
380
missouri
clearance?
How is the clearance for the firewall? I have a s10 with a 350 as well. Ive heard the LS motors can handle more power than the older blocks.
Horsepwraddict
1,581
Princeton MA
my driver side head is maybe 1cm away from the firewall, maybe a 1.5 cm's.....its close.
i had to grind off the ends of the screws that come through the firewall to mount the gas pedal because they were hitting the head.
wgnguy
380
missouri
ahh
yeah I have seen some of your project pics....Im not wanting to ge into all that welding you have done.....so I have to ask is it needed? Im not bashing your work..I just want to know how much work this swap involves. Thanks
