60ft improvement
darius smith
206
fort valley, ga
i have a 5600 converter in good air but this time of year its more like a 5400. Before i changed gears i was trapping at 7600 in the 1/4 and in hi gear before the 1/8. since i didnt run the 1/4 i cant tell but by rule of thumb its 300rpm for every gear ratio. so i'll say in the 1/4 i should trap about 6700
darius smith
206
fort valley, ga
yeah i have to do the same because that converter i'm using was behind a 14 degree 406 that made about 750hp. i bought it and stuck it behind my motor because it had the same stall(5600) that i needed. i will do that and a t-brake while i'm getting the other motor ready.
scuba_steve's_bu
440
Rock Rapids, Iowa
i changed from 3.73 to 4.11 about a month ago. my 60ft did improve a little, but also put slicks on from the drag radials too.
slimbo
4,223
www.yellowbullet.com
it all really depends on where the motor makes torque. a nitrous or big cube motor doesnt need a ton of gear. my buds nova has 3.55's and runs 10.50's and 60's in the 1.50 range. most of the time more gear is needed is to put the motor higher in the rpm range if thats where it makes torque. if your down on power usually going higher (numerically) in gear will speed it up. usually the more torque you make the less gear you need.
PONTIACMAN3
459
Manville, NJ
Slimbo I put a powerglide trans in my car with a 2500 rpm converter, it seems to come out of the hole very slow now compared to the t350 with a 5500 rpm converter, what should i do???????
64chevelle
61
wichita ks
With my current combo I am running 3.31 gears..It has been 10.70 with a 1.62 60" and 9.72 1.40 60'...just changed gears to a 4.10 and going to track for the last time this year tomrrow...results to come!
