7.5 in rear
malibu78
21
im currently working on putting a 350 (350 horse/400lb ft) and a 700r4 into my malibu. I was wondering if its worth building up the stock 7.5 rear with a posi unit and 3.73 gears or sourcing out an 8.5 from a grand national which i kno can be expensive.
lasttime78
465
If your going to race it every week-end and run slicks it won't last. If your going to build a nice street car and get on here and there at lights and stuff,. It will be fine,but any more hp I would seek out a bigger rear-end.
Brown_Gbody
3,078
Milwaukee, WI
It's my set up exactly, and for as few times as I break the tires loose, I'm fine with it. When I win the 540 million lottery tomorrow, I'll buy a 9 inch for the car. First thing!
Good axles and a bearing support cover are your friends :) Put good parts in it and you should have no issue with it... I have a stock open high-miler 2.29 behind a 375ish hp/4-speed combo and it's been fine for the couple thousand miles I put on it, but I also don't beat on it (clutch dumps, hard shifts, etc.). If you take care of it, it will last.
dickeymoore
818
Atlanta,Ga.
I have a stock 7.5 with 373 gears in my Monte Carlo SS with a 425+hp SBC 406 been working fine for me for years, has a aliminum differential cover with bearings support studs, only use on street no slicks.
IMO, the cost of updating the 7.5 is so close to what a GN rear costs, it's a no-brainer. Go with the 8.5. It''s probably stronger stock than an updated 7.5". I've seen updated 7.5" rears pop on peacefully driven mild V6 automatic cars...
