700R4 driveshaft length???'s
dickeymoore
818
Atlanta,Ga.
I have a 1978 Monte Carlo that I will be putting a 700R4 trans in it with a 7.5 rearend behind a SBC 400 engine does anyone know what length size driveshaft I will need or what car I can get one out of from the junkyard that will bolt right in?THANKS
DOUG213XRJ
4,671
West, MI
Your drivshaft can be shortened. It will be three inches shorter, But you should measure it to be sure.
SSedan64
948
MACON, GA.
Doug is correct ^^^ best to measure but, 3" shorter is the norm.
Lots of good Tech/Swap Info here>> http://www.maliburacing.com/tech.html
dwkohout
529
Albany,MN
The stock driveshaft in my 84 was 52 1/2" and I found the 2nd gen f-body driveshafts are 3" shorter.
4,686
32
The original driveshaft (with 7.5-inch axle) is 52.5 inches long, so you need one that is 49.5 inches long.
In my experience, 1970-1981 F body driveshafts (from chevrolet V6/V8) are 1 inch too short (48.5) if your G body has a 7.5-inch axle. A 1981 F body driveshaft from a Buick V6 car is the right length (49.5).
I am told that the first gen firebird driveshaft is the right length.
