700r4 swap
I believe the only difference in a GN trans is servo and valving, I don't think it's anything too major that wouldn't get changed with a rebuild anyway. That's the other thing about 200s, I believe they're more expensive to build up, but if it's going to be in there a while I think it's worth it for closer gear ratios. PATC (these are the guys that make the Raptor 700R4) DOES have a different 1st gearset so first to second isn't such a major drop, but it's pricey. Search for "power gear" on the page.
http://www.transmissioncenter.net/competition.htm
melloelky
3,654
31
mass
MISFITmalibu63 said:
would i be able to snag a 200r4 from a GN or is that a different bolt pattern?? would be convenient because im using a GN rear with the 3.42 ratio
time to do some reading ](*,)
no sir the 200r4 has two bolt patterns,it's meant to go behind a buick old pontiac or Chevy mill.got one in mine it bolts up just fine.
SSedan64
948
MACON, GA.
Many of the 2004R from Low Performance vehicles did shift early. The BQ,BR,CQ,CZ,OZ,KZ coded Trans don't.
Some early 2004Rs have only BOP mount pattern.
The CQ,CZ,OZ or KZ coded Trans would be better for a V8, they'll have the highest rpm Auto shifts. BQ/BR code would work well with 3.42 gear, it'll shift around 4700-5000rpm.
BOP Only:
DOUG213XRJ
4,671
West, MI
Call Art Carr 1 800-278-2277 . 4700 to 5000rpm in a mild small block chevy is still early.
4,760
BOP Only:
That is the first BOP-only TH200-4R I have seen. I have only ever seen CBOP patterns on a TH200-4R.
SSedan64
948
MACON, GA.
BOP Only:
They're not very common.
All Chevy cars came with BOPC+Chevy UniBell pattern.
There are no Chevy only Bell patterns, as far as I know.
BOPC = BuickOldsPontiacCaddy
SSedan64
948
MACON, GA.
Yeah, the BQ/BR codes are for Buick Turbo-V6 w/3.42 gear which don't Rev like a SBC.
The CQ/CZ = SBC/305, OZ/KZ = BOP/307 codes Auto shift around 5500rpm and are tuned for 3.73 rear gear.
Lonnie @EA/ExtremeAutomatics has a Valvebody calibration machine & can setup what's needed. I think Chris @CKPerformance also has one.
