aluminum vs steel brake drums
is there any kinda advantage other than weight between the two? :?:
Hiway
3,932
Enola Arkansas
Alum. ones are a little thicker...as in wheel spacing.
ok was just wondering someone was telling me that it helps performance alittle because they weigh less and that means less rotating mass or something like that. i am not a physics major by any means so i figured what better place to get answers than posting a msg. i couldnt figure out why that would make a difference other that weight and better cooling.
Hiway
3,932
Enola Arkansas
Like you said in your first post...weight is the advantage.
ok, weight it is. thx i guess i will get some for the weight since i plan on shedding a few pounds off the ride. every pound counts,right?
CARRS78BU
108
Butler, Pa.
Hey, let me know if you are still going with the aluminum drums. I have a mint, fresh turned set that I took of my 27,304 mile 78.
Pat
