What's the best metal plug to screw into an aluminum radiator? I installed a Cadillac transmission cooler and want to bypass the radiator. I need plugs to fill the holes where the lines are going now.
probably pop the rad out and run your hose through the ports until no more trans fluid comes out, then the water will just evaporate, that's what i'd do at least.Thank you. What's the best way to get the fluid out?
