Best paint for the differential cover.
78elk
1,294
81
Mountain Home Id
I've been having problems with the rear differential cover leaking oil. I've tried different gaskets and glue and nothing works. So I had a coupon from National Parts Depot, so I bought a new steel differential cover that needs to be painted. What is the best paint to use?
r_d_3
125
67
28
29
New Jersey
I like Rustoleum brush on paint for that kind of stuff, that's what I painted my rear axle with.
78elk
1,294
81
Mountain Home Id
The cover got here yesterday.
This is what it looks like on the outside.
melloelky
3,654
31
mass
wow,looks good.you can use any paint you want.just make sure JD black(or whatever paint you decide to to use) doesn't require any adtional primers.i know some paints like they're direct to metal.meaning they don't require any primer before hand.it's good to go straight from the can.
78elk
1,294
81
Mountain Home Id
I'm thinking of doing something different than I said earlier. I have some Rust-oleum gray primer and some Eastwood's Under hood black. That would give it a primer to fight the rust and a black that fights rust also.
  • Like
Reactions: melloelky
