anybody know {sheetmetal }
79izfine
2,199
massachusetts
anyone ever buy these panels from here http://www.ecparts.net/ was thinking of using these patch panels on my bu http://www.ecparts.net/SR3206L.jpg http://www.ecparts.net/SR3205L.jpg wanted to kow if available thanks
Ribbedroof
2,894
Rural Oklahoma
From what I remember, Caminos are made differently ahead of the wheel (& longer), and the rear is obviously not correct. Behind the wheel is totally different shape between Camino and Malibu. Both areas should be doable with a little skill and flat sheetmetal.
Those particular panels I have not used, but aftermarket panels (ESPECIALLY patch panels) seldom are even close to the correct profile or style line placement.
79izfine
2,199
massachusetts
i was palnning on reshaping below the contour line , i figured its the only alternative besides a donor for me having little experience making them from scratch would be far more difficult i am surprised no one makes any the demand is high enough another idea was getting some circle track panels see if those could be worked to fit . i tried sherman on some body panel forget what and it wasnt available any way thanks for the input
Ribbedroof
2,894
Rural Oklahoma
Below the line is pretty simple...very mild curvature, and a sharp bend where it kicks in to the trunk closeout panel. flat sheet should be very doable, unless the edges are gone...then patch panels usually aren't enough anyway.
