anybody running 15's with the big brake conversion?
Malibu 361
1,286
Queens,NY
Anybody running 15's with the big brake conversion?I am looking to run 15's up front (WELD Draglites)but have heard so many diffrent sizes and backspacings...If there is anybody getting away with it please let me know rim brand,backspacing ,rim size ,and tire size it will be GREATLY appreciated..Then I can finally be out after 7 years!!!!...Thanks again ,Sal
355_79bu
1,240
Cotter, AR
15x8 or 15x7 4.5" backspace and you will be good to go. Personally I would go 15x8. I don't know if you have your rear wheels yet, if you don't go with a 4" backspace and your front wheels wont stick out further than the rears. As I said before, I had 15x8 4" backspace all the way around, with about 1 3/4" drop in ride height in the front and the outside edge of the tire hit the upper most part of the fender lip when you hit a large bump, but they barely hit. The additional 1/2" of backspacing would have cured this problem, as well as looked better because the fronts were noticeably sticking out further than the rears. If you have lowered the car and have a decent sized tire, the tire may rub the sway bar on the front edge of the tire and the inner fender on the backside of the tire at full lock. It is not that serious though and a XH steering box with 16" wheel stops would fix that problem if it bothers you. The 15x7 might also cure that problem, but it will leave you with a little less tire width options.
Malibu 361
1,286
Queens,NY
Thanks again i was planning on 15 x7 with a 4.5 bs My back rims are 15 x 8 with 4.5 bs so I guess well se how that goes thanks again...I just wanted to be double certain before I order my rims....Sal
200KSS
534
Southeast Missouri
Stock alum. 86-88 Monte SS wheels are 15x7 and will work with the B-body spindle swap, or 1LE brakes as they are known.
vtakiaman
25
Ventura, Ca.
15" with big bvrakes
Yes 15"X7 or 8 if you go smoller the brakes will lock up the tires and skid. Beleive me I know. Check picture.
http://elcaminocentral.com/gallery-photo_Jim-s-87-Project-IMG_2637.html
Malibu 361
1,286
Queens,NY
What size rims did you have when that happenned ..and why did they just lock up ?Ws it because they were too small?what size backspacing were the rims and what kind of spindles are those on your page you have pictured?Thanks,,,,Sal
vtakiaman
25
Ventura, Ca.
the spindles are from a 96 caprice. The rims I had were 15"X4" when I had the accident. I now am running S-10 rim's 15"X7" with 225/50/15 tires and have a hard time locking the brakes up now.
