Axle bearings...
How many different sizes are there? I'm thinking someday down the road I might get something like a B-Body 8.5" and have it shortened to a stock G-Body width. Are there differences in axle bearing (not carrier/pinion) sizes?
Ok... found out a little bit... source was RockAuto.com
'94 Caprice rear:
sedan: Timken #5707 / AC Delco #RW2009 (1.400 IN ID X 2.251 IN OD X .697 IN THICK)
BUICK (1982 - 1996)
CADILLAC (1982 - 1996)
CHEVROLET (1982 - 2005)
GMC (1982 - 2005)
OLDSMOBILE (1982 - 2001)
PONTIAC (1982 - 2002)
wagon: Timken #6408 / AC Delco #1559TS (2.078 IN ID X 2.532 IN OD X .803 IN THICK)
BUICK ELECTRA ESTATE WAGON (1984 - 1989)
BUICK LESABRE ESTATE WAGON (1982 - 1990)
BUICK ROADMASTER 1991
BUICK ROADMASTER ESTATE (1991 - 1995)
BUICK ROADMASTER LIMITED WAGON 1996
CADILLAC BROUGHAM (1987 - 1990)
CADILLAC COMMERCIAL CHASSIS (1982 - 1984)
CADILLAC FLEETWOOD (1982 - 1984)
CADILLAC FLEETWOOD BROUGHAM 1986
CADILLAC FLEETWOOD FORMAL (1982 - 1984)
CHEVROLET BLAZER (1982 - 2005)
CHEVROLET BLAZER TRAILBLAZER (1999 - 2001)
CHEVROLET C10 PICKUP (1982 - 1986)
CHEVROLET C10 SUBURBAN (1982 - 1986)
CHEVROLET CAPRICE (1985 - 1994)
CHEVROLET CAPRICE CLASSIC (1982 - 1996)
CHEVROLET G10 SPORTVAN (1982 - 1993)
CHEVROLET G10 VAN (1982 - 1995)
CHEVROLET G20 SPORTVAN (1982 - 1995)
CHEVROLET G20 VAN (1982 - 1995)
CHEVROLET IMPALA 1982
CHEVROLET K10 PICKUP (1982 - 1986)
CHEVROLET K10 SUBURBAN (1982 - 1986)
CHEVROLET P20 VAN (1982 - 1989)
CHEVROLET P30 VAN (1982 - 1991)
CHEVROLET R10 PICKUP 1987
CHEVROLET R10 SUBURBAN (1987 - 1988)
CHEVROLET R1500 SUBURBAN (1989 - 1991)
CHEVROLET S10 PICKUP (1994 - 2003)
CHEVROLET V10 PICKUP 1987
CHEVROLET V10 SUBURBAN (1987 - 1988)
CHEVROLET V1500 SUBURBAN (1989 - 1991)
GMC C1500 PICKUP (1982 - 1986)
GMC C1500 SUBURBAN (1982 - 1986)
GMC G1500 VAN (1983 - 1995)
GMC G1500 VAN RALLY (1982 - 1993)
GMC G1500 VANDURA (1982 - 1995)
GMC G2500 VAN RALLY (1982 - 1995)
GMC G2500 VANDURA (1982 - 1995)
GMC JIMMY (1982 - 2005)
GMC JIMMY ENVOY (1998 - 2001)
GMC JIMMY SLS (2002 - 2004)
GMC K1500 PICKUP (1982 - 1986)
GMC K1500 SUBURBAN (1982 - 1986)
GMC P2500 VAN (1982 - 1989)
GMC P3500 VAN (1982 - 1991)
GMC R1500 PICKUP 1987
GMC R1500 SUBURBAN (1987 - 1991)
GMC SONOMA (1994 - 2003)
GMC V1500 PICKUP 1987
GMC V1500 SUBURBAN (1987 - 1991)
OLDSMOBILE CUSTOM CRUISER (1982 - 1992)
PONTIAC PARISIENNE (1983 - 1986)
PONTIAC PARISIENNE BROUGHAM 1983
PONTIAC SAFARI (1987 - 1989)
So from the looks of it, it'd be better to get a wagon rear, bigger axles & bearings :) Thanks guys dancin_banana.gif :D
monzaz
704
Richfield, Oh
www.jdrace.com
Well that may not be a good idea as the larger bearing will end up being categorized as a truck axle and be more money in the custom c-clip axle world.
There are NO short axles with the larger bearing from GM. 30 3/8" is as short as they come.
So if your going to shorten a rear and buy aftermarket axles you might as well do the ford bolt in bearing with a GM mid size car flange 7900 Moser part number. Then you will have the best for drag race and street duty also.
IF your not going with more 11.99 et car then just stick with the c-clip 1.40 axle bearing surface ...It will be MORE than strong enough for the job and if you do go faster you can just lob off the ends of the housing and c-clip elim kit the rear.
PLUS these axles at off the shelf axles 28 or 30 spline from Moser and will only cost 250.00 Jim
kevind
868
Whitley City KY
A 12 bolt car and a 8.5 from a 71 to the time the went to a 7.5 Nova use the same wheel bearings. I have taken alot of Impala housings cut them down and used the nova ends on them. I think even the 8.2 10 bolt uses the same wheel bearing. Is the angle of the top arms the same on the Impala rear 70-71 as a Chevelle or ? There should be plenty of them around. May be a cheap 12 bolt I have bought a bunch of Impala 12 bolts for $100-$150
Well, I recall someone (has an orange-ish street-driven wagon with an LS motor) said he drilled out the 2nd hole in stock upper arms to correct pinion angle and that was about it as far as adapting goes (probably need to relocate the spring perches also), but for the price I'd pay for a semi-local G-Body 8.5 (timing is everything, and I'm nowhere near needing one, not for quite some time) I could probably buy a B-Body 8.5 (~$250+ around here) & have it shortened.
How much more would a shortened axle like that run... for the larger axle I mean? The reason I considered it is because of the larger bearing and larger diameter axle, I recalled reading they could be shortened and re-splined. If that's the case, I figure after all is said & done I'd have a pretty bulletproof 8.5 with 30-spline axles (although I don't know all the ins & outs of rears, 30 is better than 28 or 26, and a thicker axleshaft is better, correct?), probably a support cover, and a good posi unit.
monzaz
704
Richfield, Oh
www.jdrace.com
Old stock axles are junk. HArdly any one resplines axles any more. The price of shipping to the shop (moser) then the respline price and then the shipping back your pretty much at the price of a aftermarket c-clip alloy axle pair...lol. The alloys they use in the aftermarket axles are far superior to stock cast axles.
To save 50.00 it is just not worth the effort. :)
I have a friend that still has big c-body mopar axle cut resplined for Mopar stuff but a bolt in axle is a custom axles and will cost 345.00 + shipping compared to a c-clip axle being from 199-249.00 + shipping depending on where you buy the parts.
looks like resplining is 100.00 from moser and then shipping from IN to OH is 25.00 and back is 25.00 so you have 150.00 right there. Then you had to initial buy the rear 250.00
400.00 so far.... gears 150.00 bearings 100.00 posi ( used 100-250 depending on type) narrow the housing local 100-150
blast the housing paint 30-70 ish
Numbers, numbers... numbers...
The resplining I was talking about was on new axles. If I bought one of these rears & had them shortened I'd be using new aftermarket axles from the start.
monzaz
704
Richfield, Oh
www.jdrace.com
You can buy what ever axle you can think up in the aftermarket...lol. BUT if you can keep the length to a stock 28 7/16 " axle and a stock off the shelf spline count like 28 or 30 you can get them pretty reasonable. Jim
