So i pulled the rear end out to put new adjustable control arms,adjustable shocks,drum brake kit and girdle support cover on this 7.5 I have and i'm not sure if the play in the axle to housing is ok to run like this. The rear is complete and supposed to be ready to go but i wanted to freshen up a few things. Got the drums off and realized that the drivers axle would pull out of the housing about a 1\16-1\8 of an inch or more, The passenger axle is about half that. And the center pin in the posi unit has alot of wear on it from the axle coming in and out and contacting the pin.
I am far from knowing what is suppose to be right in an axle but I dont think this is acceptable. Am i wrong? If not what can i do about fixing this problem? Is there different sized c-clips or is this a bearing problem? Im not sure where to go from here and need to get this rear back in so I can put the car back in the garage before it rains on me. ( no weather stripping on the car yet)
Thanks again guys!
Thanks again guys!
