Balanced rotating assembly
T56elcamino
55
Opelousas, LA
I am about to put new crank and rods in my engine and was wondering if it would be a good idea to get the rotating assembly balanced. Its a 383 SBC and I will have some AFR195 eliminator heads and a roller cam in it, no nitrous or forced induction. thanks.
bowtie81
5,008
sarnia, ontario canada
usually i have found if your not buzzing it past 6500 it should be ok, but it's better to be safe than sorry i would get it balanced.
CNC BLOCKS
154
NORTHEAST
WWW.CNCBLOCKSNORTHEAST.COM
I would balance it now instead of getting it in the car and finding out you have a vibration and have to take it back out and then you will know if its internally balanced or externally balanced.
I balance for alot of other shops and engine builders and I don't think I have seen one yet that you could have dropped in and not be a problem.
slimbo
4,223
www.yellowbullet.com
with the vast selection of rod/piston cominations its impossible for a crank to be even close to being balanced properly out of the box these days. spend the money.
T56elcamino
55
Opelousas, LA
thanks guys, I called a local speed shop and he quoted me $200, so I'm bringin it to him next week.
X2. It'll seem to run smoother, too. I had my OEM 454 stock stuff balanced when I did the freshening. Even GM's balancing tolerances aren't really all that tight
